getting residue signal
Hello
I have a data coming in which has spikes with high amplitudes and a base noise floor shown in figure attached.
I am looking for  a function in LV which would segregate the noise part into another array of data.
Basically i am more interested in getting the noise residue in another array and do further processing on it.
What array would I use?
Kudos to all replying.
(3,063 Views)
Hi alpine_tech,
  To remove the base noise floor which method/algorithm do you follow generally?If you know that we can try
implementing that same in LabVIEW.
SrikrishnaNF
Srikrishna
(3,056 Views)
Rite now I am not using any algo to remove it. The output is coming from an algo which outputs signals in terms of energy.
So how should I acquire noise signal into another array is my question ?
(3,038 Views)
