getting the top of the analog pulse output
Hello, Guys,
Another question....
I'd like to obtain just the top of the pulses....so I am using Analog SW Trigger.vi to do so.  What I'd like is for the VI to input only the top of the pulse and do some sort of averaging technique to get a number and display that value progressively and store it into a file.
At this time however it is not wokring as planned.
The bugs I am still trying to solve:
0.  put individual timestamp along with the pulse top data
1.  the cutoff is not absolute.  If I set the window floor to 2.0...there are numbers less than 2.0 still bleed into the array and likewise for window ceiling.
please advise,
ck
(2,458 Views)
ck,
Have you tried to do this in software by just disregarding all data outside of the window which you specify?
L. Allen
(2,443 Views)
