getting trial version of adaptive filter toolkit
I am Hisham Elgannas, PhD student at Florida institute of technology. I have Labview 2009 and first I need to upgrade it to Labview 2011. second , I need to try the adaptive filter toolkit (trial vrsion if that possible). I do research on interferomter sensors and I use the labview to acquire and digitaly process the data. I need to see how the adaptive filter and the noise cancellation toolkits work with me so that if they worked with me then I will purchase it. please tell me what should I do in order to upgrade my labview and to have trail versions of the above mentioned toolkits.
regards,
Hisham Elgannas
3215573871.
(2,507 Views)
the eval version of the tool kit can be downloaded from here
You didn't need to SHOUT
(2,501 Views)
Hey Hisham,
Regarding upgrading from LabVIEW 2009 to LabVIEW 2011, you will want to talk to you IT department or System Admin to see what licensing agreements your institution has. They will most likely want to get in touch with their Account Manager and see if they have a license that will work with LabVIEW 2011.
As Jeff pointed out, you can download a trial version of the toolkit from that link.
Hope it all works for what you are trying to do!
Joe S
(2,491 Views)
