getting .vis from .dll ????
Hallo,
 Is it possible to get the .vis or .llb from a .DLL.. My main aim lies to determine the Prototype settings that are used during dll creation.
 Any reference/link/ is greatly appreciated..
Abhi
Message 1 of 11
(4,461 Views)
Hey Leo,
No, it's not possible. Try to get a documentation from the provider of the dll.
BR, Christian
Message 2 of 11
(4,445 Views)
If I understood you correctly, you want to see the function prototypes of your LV DLL.
When you create a DLL with LV, the application builder also makes a header file in
the same directory with your DLL. From this header, you can see the prototypes.
Hopefully this helps.
Message 3 of 11
(4,444 Views)
Yes Kaeam, you are right, It served my purpose.
Thanks ,Smiley Happy
Cheers,
Abhi
Message 4 of 11
(4,426 Views)
If it is a LV-built Dll, maybe you can try out changiing the file extension as .llb & then open it to see all the VIs required to build that Dll. This is a similar procedure as that of viewing the internal contents of an LV-built EXE. But I think, you wont get to see the code, as the diagram would have been removed.
Try it out n post Ur feedback here.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 11
(4,423 Views)
Happy to see that Ur problem got solved. But the header file will get created only when the Dll is built for C Calling conventions, I think...
Anybody please correct me if I m wrong.
Message 6 of 11
(4,422 Views)
So it seems that yourself is the provider Smiley Wink
The possibility to get the llb or vis out of an exe or dll changed since LV8.x. Befor it wos possible if you simply change the extension to .llb. Since 8.x you have to enable VIServer for the project to access them. And yes, you only have an .h file for C dlls.
BR, Christian
Message 7 of 11
(4,414 Views)
Works for standard calling convention also.
The function prototypes in headers looks something like this
uint8_t __stdcall function(...);
long __cdecl LVDLLStatus(...);
So, you can see the calling convention from here also. The LVDLLStatus function is automatically
generated and is good for debugging. See the LV help for info on this.
Message Edited by kaêm on 11-23-2007 01:00 PM
Message 8 of 11
(4,413 Views)
Hi Christian & Kaem,
Thank you guys for your info.
Message 9 of 11
(4,405 Views)
Hi all,
  I believe Kaeam is absolutely right, the .h files are created for both C calling and standard calling functions..
Partha, as you said, to change the extensions, sorry Smiley Sad but dóes nt work as Christian said,
Abhi
Message 10 of 11
(4,401 Views)
