gfortran
labview2014を使用。gfortranでdll(32ビット)を作成しLabview から呼び出そうとしましたが、ライブラリ関数呼び出しノード/test1.vi
でクラッシュします。メモリー番地の不具合みたいなのですが、どうすればいいのかわかりません。どなたかご教示お願いします
Message 11 of 18
(898 Views)
LabVIEW側の定数 0 のデータ型が、DBLであることが気になりました。
Message 12 of 18
(882 Views)
singleでもdoubleでも駄目でした
Message 13 of 18
(859 Views)
Will you show me what yo mean 5 element.  The elements are a,b,sum and product.
So Ithink  elements to bo 4.and all elements are single precision. My code is below
module test_module
use iso_c_binding
implicit none
contains
subroutine test(input_value1, input_value2, sum, product) bind(C, name="test")
real(c_float), intent(in) :: input_value1, input_value2
real(c_float), intent(out) :: sum, product
sum = input_value1 + input_value2
print * ,input_value1,input_value2
print *, "Sum: ", sum
product = input_value1 * input_value2
print *, "Product: ", product
end subroutine test
end module test_module
As I wrote before,Fortran is Gnu Fortran newest version. Compile was done 32bit spec..Labview is 2014 32bit
Message 14 of 18
(855 Views)
module test_module
use iso_c_binding
implicit none
contains
end subroutine test
Message 15 of 18
(815 Views)
As someone who once knew how to program a Card Punch to make "Fortran-specific" punch cards, I can tell you that "Anything FORTRAN can do, LabVIEW can do better" (and, undoubtedly, faster, clearer, and with fewer "Programmer Errors", particularly "spelling" mistakes).  I'm sure your Fortran code is much more complex than adding and multiplying two Reals and printing the results, but I'll wager (my standard stack, a dime, or 10 cents) that it would take less effort to code the Fortran part (I forget what the proper "capitalization" rule is for FORmula TRANslation) (LabVIEW knows a lot of "special functions" ...).
Bob Schor
Message 16 of 18
(828 Views)
voce pode incluir DLL ?
Message 17 of 18
(819 Views)
Thank you for your link reply. The complex code was the result from CHATGPT. At first
code is very simple but error occured. So  I must seach if the main cause is dll or Labview or combination of them.After 2 days of work,the main cause of trouble may be the transfer of the data between them.But improvement stopped because I can do nothing any more .So I asked someone  for help.
Message 18 of 18
(799 Views)
