gives input to the graph
Your VI is missing some subVIs, and it is impossible to run. But from the graph properties I saw that all plots were assigned to the same axes.
In the image below I assigned Amplitude 2 as Y-axis to Plot 1. Please check once more in your VI.
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
Message 11 of 16
(1,330 Views)
where should i do this changes? @GredW
Message 12 of 16
(1,326 Views)
Right click on the graph on the front panel, and select "Properties" from the shortcut menu. In the Properties window open Plot tab. There you will see all required setting for axes.
Arev
Message 13 of 16
(1,322 Views)
Ok I will try,and let you know
Message 14 of 16
(1,317 Views)
I already did that settings but still it is giving reading to first Y-axis, please guid me how to separate that both voltage and cuurent readings from  2D array so as I can plot it by giving input to graph separately for first Y-axis and for second Y-axis
Message 15 of 16
(1,301 Views)
Hi kiwagh,
all this has been shown before. You can even select doing it in the properties dialog of the graph or programmatically in the VI…
Why ask the same again and again?
Message 16 of 16
(1,285 Views)
