global access configuration file
is ther any limitation while devolping cgi in 8.2
Message Edited by mazhar.ali on 08-27-2008 09:43 AM
(3,587 Views)
You will need to provide more details. Your question is far too vague.
(3,583 Views)
thanx for interest
we have to devolp an application in pure html format without using web publishing and web server
regards
mazhar
(3,563 Views)
Unfortunately, that still tells me little. What do you mean "in pure html format without using web publishing and web server"? What does this have to do with LabVIEW? Are you trying to run a LabVIEW VI in a web page? Are you trying to serve pages from LabVIEW?
(3,550 Views)
Hi Marzar,
If you are the same person who posted this quesion on LAVA, then you are being consistent in not making your request clear.
If you are not comforatble with English, then please post your question in your native language and someone will either translate or will reply in your prefered language.
Trying to help (but not sure how),
Ben
(3,542 Views)
Hi Ben,
            I am trying to view my vis in webpage format but i don't know how to create a simple appalication in labview by using webserver(G web server) and Cgi vis. I am failed to get any proper guidence that how to create a simple application i m thankful to you if u send me the simple application code.
(3,514 Views)
Hi Ben
thanx actually this question is from jawad may be he can explain
regards
mazhar
Message Edited by mazhar.ali on 09-01-2008 05:18 AM
(3,481 Views)
