global variable and reference
Could you tell me the difference between the "global variable" and "reference" ?
If i create a control in a VI and i need to use its value in a subVI should i use a reference or a global variable ?
In the other hand, if i create control in a subVI and i need to use its value in a VI should i use a reference or a global variable ?
If you could explain me by a VI that would be wonderful
Thx,
Samer,
(3,047 Views)
Hi Samer,
I wrote the Action Engine Nugget to illustrate a safe and effective way of sharing data between multiple thread.
Re: your Q
Both gloabl variables and reference>Value are subject to potential race conditions.
Globals require all of their instances be updated anytime one is updated. So they dont' scale well either.
References force a thread switch to the UI thread (single thread so this is a bottle neck)
So PLEASE take a look at that Nugget.
Thank you,
Ben
(3,041 Views)
