global variable cannot hook up to Excel Easy Table data in node
Darren,
Problem solved. I want to tell you how I fixed it so others might find it helpful. The String to Number vi rounded up the fractions I need so it was not working. I did find one that did work however. On the Strings palatte under String to Number Conversion icon is a vi named Fract/Exp String to Number Conversion. This allows fractions to be untouched and passed to my Excel spreadsheets.
Thanks again for your help.
Larry
Message 11 of 12
(549 Views)
Sounds good, Larry.  In the sample VI you sent, the global variable was an integer datatype, so I suggested the number to string conversion function for integers...had it been a floating point, I would have suggested the Number to Fractional String function you found.
-D
Message 12 of 12
(546 Views)
