global variable
in the attached llb ...there is a vi named global bus config..in that global variable there is busconfig block on the front panel..and in that in the "name" indicator there are the name of various PME's which i am using ..in the 13th number PME there is BEHLMAN stored there if i want to change the name and write some other instead of it ..how can i bring the change..i have already tried to edit the name and write some other name instead of it and i also have saved the changes...but every time i close it and reopen it ,the name behlman again appears ..how can it be changed...please help me in this...thanks note: the vi is compatible with labview 7.1 version
(2,380 Views)
(2,362 Views)
