global variable
in the attached llb ...there is a vi named global bus config..in that global variable there is busconfig block on the front panel..and in that in the "name" indicator there are the name of various PME's which i am using ..in the 13th number PME there is BEHLMAN stored there if i want to change the name and write some other instead of it ..how can i bring the change..i have already tried to edit the name and write some other name instead of it and i also have saved the changes...but every time i close it and reopen it ,the name behlman again appears ..how can it be changed...please help me in this...thanks note: the vi is compatible with labview 7.1 version
(3,139 Views)
You have to right-click on the control and select Data Operations -> Make Current Value Default.
Aside: That library is poorly written. There are global variables EVERYWHERE.
(3,127 Views)
If you can, I would strongly recommend you replace the global variables with single-element queues or actions engines.  If you can upgrade to a more modern version of LabVIEW, use data value references.
(3,125 Views)
thanks..it really worked for me...
(3,095 Views)
i wish i could but its difficult in my case....anyways thank you so much for the advice...
(3,093 Views)
(3,093 Views)
