global virtual variables from RT
Hello, I have created a vi to programatically choose global virtual channels from RT using the Browse Object Variable. I upgraded to LV2010 and this works in the development computer but when I build the installer and install it on another computer the browser does not display my RT. This used to work in LV2009 so I think I am missing some installer. I have looked at the available ones under the installer properties and I chose all that I thought would apply. I have attached the picture of the browser with RT displayed 192.168.0.20 and the NI software installed on the test computer. Has anyone encountered this problem? I'll appreciate any help. Thanks
Labview Run Time 8.2.1
Labview Run Time 8.5.1
Labview Run Time 2009 SP1
Labview Run Time 2010
Measurement and Automation Explorer 4.7f4
Measurement Studio for VS2005
NI PXI Plataform Services 2.5.6
Ni System Configuration 1.1.0f3
NI-DAQmx ADE Support 9.1.5
NI-DAQmx Device Driver 9.1.5f1
NI-DAQmx MAX configuration 9.1.5
NI-PAL 2.5.4
NI-VISA 5.0
NI-Visa Runtime 5.0
(3,020 Views)
Accepted by topic author Bertha
Found the problem, I used msiblast to find any other NI installers and erased all National Instrument left over files and folders from uninstall in test computer using search and it works now.
(2,999 Views)
