gpib bluetooth
I need know if there is an device that make interface between an instrument with output GPIB and an PC with Bluetooth with labview?
(3,949 Views)
You kind of lost me on that one.  You want to connect a GPIB device to a PC using Bluetooth? Never heard of that, though apparently somebody proposed it. Don't know of any devices on the market, though. I think you'll find the USB <--> GPIB method to be easier to use and more available. NI has such an interface: https://www.ni.com/en-us/shop/model/gpib-usb-hs.html. There are others on the market.
(3,937 Views)
If it is wireless you are after, granted it's a stretch but you could use a GPIB-ENET/1000 ethernet to GPIB controler  with a wireless router.
=== Engineer Ambiguously ===
(3,927 Views)
I don't believe bluetooth can push data as fast as GPIB can, so there's going to be some latency in that link.  WiFi's probably a better option there.
There are Bluetooth-to-RS232 modules out there, if the instrument has an RS232 (serial) connection.
(3,915 Views)
