gpib error 0
Hi csab,
8 years later you have exactly the same problem (using the same functions on the same hardware using the same LabVIEW version, the same GPIB driver, and the same VI)?
@Csab87 wrote:
I want to kindly asked: How solved it this problem?
To solve this problem you need to provide more and relevant information. Attaching your code (aka VI/snippet) would be a good start…
Where/when do you run into "error 0"? Is this really related to GPIB at all?
Message 11 of 13
(981 Views)
I had managed to set the baud rate to 0 ... so the solution was to set it to a valid value.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 13
(963 Views)
Message 13 of 13
(906 Views)
