gpib interface is missing
I built an .exe and can work with it so far. The last step is creating a report (excel). Creating reports is working fine in the development environment but not via the .exe. Then I get the attached error message. What does it mean and what can I do?
Thanks!
Message 1 of 16
(7,159 Views)
Error code 7 has two definitions.  One is from GPIB.  But since you are not doing anything with GPIB, you can ignore that part of the explaination.  The other part is File Not Found.  That is what you are having problems with.
The Report Generation Toolkit uses dynamically called classes.  Since they are dynamic, they are not automatically included in the EXE.  So you need to use the Alway Include option in the executable properties on the following folders: <LabVIEW>\vi.lib\LVClass and <LabVIEW>\vi.lib\NIReport.llb.
Message 2 of 16
(7,155 Views)
One of the first things I had to learn - for survival's sake - was that you can have multiple error definitions for a LabVIEW error code.  It will list all the errors for that particular number and it's up to you to determine which one it is.
In your case, there are two clues as to which one it is.  The first clue is that you are doing file operations.  The second is that you aren't making use of GPIB (if one even exists on your computer).  If you were using GPIB, you might have to check where the error is coming from.  e.g., If your subVI names are descriptive enough, the path will give you a big clue as to which error description describes the error.
Bill
CLD
(Mid-Level minion.)
Message 3 of 16
(7,123 Views)
I set the NIReport.llb to always included - I don't have more choice to choose. But it's not working... I get the same error while generating the report. Any other idea?
Message 4 of 16
(7,103 Views)
Susanne1709,
In the Application Builder, try to click on Advanced and enable the option Pass all command line arguments to application.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 5 of 16
(7,094 Views)
it looks like a little bit better because Excel opens for less than 1 second and closes again. The error message is the same Smiley Sad Smiley Frustrated
Message 6 of 16
(7,085 Views)
put a Clear errors Smiley Very Happy
syrpimp
Message 7 of 16
(7,081 Views)
? what does that mean?
Message 8 of 16
(7,073 Views)
In your code, try to check for this specific error code. If you have this error, use the Clear Error function. And test what you get in this case...
So in the block diagram of the "NI_Excel.lvclassnew........" subVI...if you clear this error, you may get you want. But not fure sure 😉
Message 9 of 16
(7,067 Views)
I need to install it before. Then I will try to put this Error VI after the VIs where the error comes up, then I try your suggestion.
Message 10 of 16
(7,061 Views)
