gps simulation kits problem
I used the GPS kits example "niGPS Write Waveform To File For Trajectory Mode Simple" to generate outputs. It's said there are satelltes signals 1,3,13,16,20,23,25,31,  but I could not find any signal in the output data.   I double checked, and have no idea what's going on.
(2,998 Views)
I attach the output file.
(2,995 Views)
Can I ask how you are verifying that there is no signal in the output data.  Are you just running the Streaming File Output example with your bin file and checking the spectrum?  Can you run one of the example .bin files such as the everest one and see if anything is generated?
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(2,947 Views)
