gps
hi, I have a program that can generate the time based on the GPS system. But now, I have a problem to set the time based on the computer system because I don't want to use GPS anymore in my whole system.
part of the program can be seen on the attachment.
Anyone can help? Thanks alot 😃
(4,151 Views)
I did not open your VI.
Before answering your question...  I have a question...
Typically, we use a 10MHz reference clock (from GPS) to synchronize instruments.
If you do not wish to use GPS to set the time base in your computer, what do you want to use as a time base?
(4,126 Views)
Hi Ray.R,
Thanks for reply.
in this case I want to use my computer time as the time base. Can I?
Because I do not want to use the GPS as the time base. Moreover, it's more complicated in testing using GPS.
(4,121 Views)
In the attachment, I figure out what I mean. I hope it can make u clear.Smiley Happy
(4,113 Views)
