grabbing usb mouse velocity
Your values look OK to be honest.  Can you asnk the supplier if the device even replies to the request, I have heard of devices not supporting this even though it's an official required part of the HID spec.
Shane.
Message 11 of 15
(1,601 Views)
Tst, he doesn't want to use the system mouse but a second mouse otherwise not shared with the OS.
Then he can't use these otherwise very useful functions.
Shane.
Message 12 of 15
(1,600 Views)
Accepted by topic author zobfish
Well you've been making progress but I don't want to see anyone suffer unneccessarily so here's a version of a VI which works for me.  LV 2011.
Greets and Grats.
Shane.
Message 13 of 15
(1,595 Views)
Thank you for the program, Shane.  It works beautifully for a different mouse, but strangely enough not for the mouse I originally was working with (the one I supplied the datasheet for).  I can work with that.  I would be interested in seeing a more detailed explanation of how you got the numbers you use, as I'm sure those who come later with a question similar to mine would, too.  In the meanwhile, I will try and figure it out on my own and post back should I come to any conclusions. Kudos and a solution for you, my good man.
Message 14 of 15
(1,575 Views)
Well all the numbers I use in the VISA call are in the document I posted a screenshot of earlier.
Glad it works for you.
Shane.
Message 15 of 15
(1,566 Views)
