graph active palette tool event?
Hello LabVIEW users,
Simple question I hope. How can detect that the Active Paletter Tool of graph has changed? The only solution I have found is to use the timeout event and to poll the property node. If you use the mouse up and mouse down event for the graph the mouse clicks on the zoom sub menu are not registered.
thanks for the help,
- Troy
(3,600 Views)
Accepted by topic author TroyR
I don't think you can, other than by something like what you did or by doing it yourself with separate buttons and code. I haven't checked in recent versions, but I assume no events were added.
You can vote for this if you want it (and see the comments) - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Generate-event-on-Selecting-a-tool-in-graph-palette/id...
___________________
Try to take over the world!
(3,594 Views)
