graph between cursors
I have a problem with cursors.
I have a waveform graph with some signal and two cursors. (annex 1)
I would like to see a signal which is between the two cursors on the second waveform graph.
Thank you for your help
Message 1 of 12
(5,655 Views)
Hi kamwoj,
read the cursor position with the help of a property node and then use ArraySubset to get the interesting part of the signal...
Message 2 of 12
(5,645 Views)
Okey, when I use property node with cursor position and array subset waveform graph show me signal from only one cursor.
What about second cursor ?
kamwoj1918
Message 3 of 12
(5,624 Views)
What about it? If you aren't using the second cursor to determine the array length, then you have not written the program correctly.
Message 4 of 12
(5,620 Views)
I meant, if in "Cursor Position:Cursor X" there are many position cursors or only one position cursor ?
Message 5 of 12
(5,612 Views)
Hi kamwoj,
you have to use the property "Active Cursor" to select the cursor you want to read it's position...
Message 6 of 12
(5,609 Views)
You first write to the Active Cursor property to select the specific cursor (i.e. 0 or 1) and then read it's value.
Message 7 of 12
(5,606 Views)
So, If I would like to use two cursors ? 🙂
Message 8 of 12
(5,590 Views)
Message 9 of 12
(5,583 Views)
Accepted by topic author kamwoj1918
Does the attached help?
Don't forget to turn off "Autoscale X" for the 2nd graph and you may want have a seperate 'condition' if cursor 2 is at a lower value than cursor 1.
Message 10 of 12
(5,581 Views)
