graph/chart softmotion problem
I have got a problem with making real time graph of axis position from solidworks assembly in labview.
In attachment is my code..
Does anybody know how to make graph of axis position in Contour Move  ?
How do you chart position independently of movement type ?
What type of graph should i use ?
Thanks in advance for the help 🙂
(2,638 Views)
Hi Bartek,
There are multiple examples in LabVIEW Find examples that demonstrates this functionality.
I would recommend specifically the one found at:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\motion\ExpressVIs\Continuous Axis Contour Move\Continuous Axis Contour Move.vi
Basically, it is using a Waveform Chart to plot the position.
IR
(2,541 Views)
