graph cursor error
Hello to all,
I am trying to add a cursor to my 3d graph and am receivng an error which causes LabVIEW to shut down. Any suggestions to avoid this error?
Thanks N Advance
(2,798 Views)
I have not personally seen this before, but definitely check out this post and the responses which seem to be the same problem:
Also, can you attach your code, or preferably a simplified example, which illustrates this so I can replicate this and explore it?  Please also include your LabVIEW version in the post.
Perhaps that 3D graph instance was corrupted.  For sanity, can you try replacing the 3D graph - does it occur with the replacement?
Ok, looking forward to your repost!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,786 Views)
