graph equation formula node problems
I am using LV6.0. I am having some problems regarding the formula in the formula node. I hope someone can help. The vi is attached
(4,374 Views)
Hi
After each line you have to write a semicolon ( ; ) and you also have to put a * before the brackets. So your formulas should look like this:
x=a*0.02;
y=0.01*(a*a + a);
Hope this helps.
Thomas
Message Edited by becktho on 10-04-2005 09:48 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,373 Views)
Thanks. The vi can now RUN. However I am getting TWO graphs instead of ONE. One is in red. I hope you can help. The new vi is attached.
(4,359 Views)
Yes, that's right. Waveform graphs and charts always show data in this way. If you want to use your x-values as x-axis and the y-values as y-axis, you have to use the xy-graph.
Attached is a screenshot of the vi.
Hope this helps.
Thomas
Message Edited by becktho on 10-04-2005 12:32 PM
Using LV8.0
(4,358 Views)
I have done a different way and it works. Is my way also correct or is there a catch?
(4,333 Views)
Hi
As I see, you now use the function "index and bundle cluster array". This results in an array of clusters.
I usually use just the bundle function, which results in a cluster of arrays.
I can't tell you if there may be problems, because I hardly use the first function. Obviously it works, but I'd suggest you to use the bundle-function, as this way is mentioned in the context help of the xy-graph.
Thomas
Using LV8.0
(4,328 Views)
