graph multiple non-continous data
On my system there are four different data sources with a common timebase, however it ist not known, when data will appear. I want to display all four data in a common graph with time as x-axis. The graph should display a certain timelength and update automatically.  Any ideas?
Message 1 of 11
(4,613 Views)
Hi
First,  kindly clarify this:  'Are you acquiring data from your four data sources(i assume them to be anlog) using 4 different AI reads?'
If you are doing something like this, then let me tell you that all four sources can be configured in a single task (group) and then, data can be acquired by using  single AI read.
select AI read type as ' Analog -> multiple channels -> multiple samples -> 2D double'.
Data acquired will be in form of a 2d array whose each row corresponding to one data source . This array be directly displayed on a Graph.
Looking at your requirement of "graph should display a certain timelength and update automatically", it seems like 'Chart' Display will suit your purpose better than a 'Graph' display. Select a suitable chart history length to get this effect
Note: Transpose the 2 D array data that comes out of Ai read before displaying it on the Chart.
hope this helps
regards
Message 2 of 11
(4,597 Views)
When a data is available build an array with 4 elements (or a cluster, it depends on which kind of graph you're using)
One element will contain the source value while the other three contain a NaN value (NaN= not a number). NaN value aren't displayed on graph/charts
Hope this helps.
regards,
manga
Message 3 of 11
(4,592 Views)
I find the multiplot X/Y graph to be a great method of displaying data.  Here the input is an array (each index is a plot) and each index is a cluster of Time, Value arrays.  See the attached (LV 7.0).  It requires some thought but you can do some great stuff with the X/Y graphs.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 11
(4,577 Views)
Sorry I forgot the attachment,
Paul
Paul Falkenstein
Message 5 of 11
(4,577 Views)
Hi devchander,
the incoming data is from a CAN-Bus which means that the data comes in as irregular serial burst. From that I extract the signals which a want. I hope that clarifies the situation.
Regards
Message 6 of 11
(4,565 Views)
Hi RichL,
Thanks for the input.
In this case, whenever you extract  data from one source, use it either to build a cluster of waveforms an plot on XY graph as Falkpl has shown, or to build a 2D array by merging that instant's data from other three sources and plotting on chart/graph.
this you can perform each time you extract data from any of the sources.
regards
Dev
Message 7 of 11
(4,557 Views)
Hi Devchander,
I formed a cluster of waveforms and plotted it in a chart. Works fine. Thank you!
The problem that each data is coming at a different time, but all data are displayed together, I solved by displaying the same data as long as there is no new one. Manga had proposed an NaN value while no new data is available, but I have not tried that yet.
Message 8 of 11
(4,521 Views)
Hi Paul,
thanks for the input! Haven`t tried it yet. I got the graphes working by forming a cluster of the incoming data and plotting it in a chart, as devchander proposed.
Regards
Richard
Message 9 of 11
(4,520 Views)
Hi Manga,
thanks for the input. I solved my problem by repeating the old value as long as there is now new one, which works fine. However your idea sounds interesting and I have to test it at some time.
Regards
Richard
Message 10 of 11
(4,518 Views)
