graph of single data
hiii
i am facing a problem with the waveform graph.
i have a single data means a random number and i want to plot the graph of that data.
you can say that i want the graph just as it is shown on CRO screen.
example:
suppose i have a data like(1,2,3,4,5,6) then it will be shown on CRO like a ramp signal and the same i want to plot.
thanks
do not hesitate to give kudosSmiley Happy
(3,344 Views)
If you are generating a single point at a time, then you would wire up a chart and not a graph. If you generated several points like (1,2,3,4,5) as an array, you would wire up a graph.
There are example programs that demonstrate the basiic operations of graphs and charts. Have you looked at any of them.
(3,337 Views)
hii Dennis
i have tried each waveform graph and chart like scope chart , strip chart , waveform chart etc...
the problem with all these is that these graphs shows the value with the ramp signal means if the data is 1 then it shows 1.its OK but when next data comes (let it be 2)then the path from 1 to 2 is a ramp signal and i want that the graph remains at 1 and when next data (as here 2)comes it shifts to 2 at the same time.
thanks
(3,322 Views)
Hi Sahil,
Isuppose you want something like this.
contact if some doubt
regards,
Shrek
(3,315 Views)
Hi sahil,
a picture is worth a 1000 words... Could you attach a picture of what you really want ? (It's unclear to me, what you mean by "remain at 1" and "shift to 2 at the same time".)
Otherwise you can play with the plot interpolation setting to get either steps or lines connecting the data points Smiley Wink
@shrek:
What is "something like this"?
Message Edited by GerdW on 12-23-2009 09:04 AM
(3,308 Views)
sorry i forgot to attach the file
(3,297 Views)
Good example shrekt to point out the difference between graph and chart!
Lets hear from sahil if this solves his problem?
Shreyas Hebbare
Shreyas Technologies
India
(3,264 Views)
