graph pallete for XYgraphs
Is it possible to use the data analysis tools in the graph pallete of xy graph using external boolean buttons? I have a requirement where the application zoom in/out and other functions in the graph palletes must trigger using the function keys of the key board. I looked in the property nodes but there doesn't seem like a way out??
Any ideas??
Best Regards
K Waris
(2,461 Views)
Use Event Structure... or another option could be create a X-control.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,431 Views)
You can use the Xaxis and Yaxis property nodes to make a zoom. You have to change the range of each axis (min and max). It will zoom on the new range.
Use Application->keyboard in an event structure to catch when the user hits a key
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(2,428 Views)
