graph plot
How to import data from excel and plot data values on waveform graph?
(4,019 Views)
You can use "Read from spreadsheet file" and use the array output for ploting. Start with the labVIEW basics and function palettes.
(4,014 Views)
Please find the below link which gives more detailed explaination with an example for ploting graph from array of points from excel file.
http://forums.ni.com/t5/LabVIEW/Read-from-spreadsheet-and-plot-multiple-XY-graph/m-p/1965063#M651419
(3,972 Views)
"read from spreadsheet file" cannot read from excel files as some others above seem to suggest.
Do you have an example file? Is it really excel or just a delimited text file? What program was used to create the file?
Do you have problems reading the file or problems graphing the data, or both?
If this is a programming question, show us your code attempts.
(3,965 Views)
