graph switching
Hello all, just a short question: is possible in LabView instead to plot two graph, have one only graph and a kind of button that switch between them?
Just an example to fix the idea: I create two arrays, for example one line and sine wave, then I could plot them in two separated graphs, but this is often space-consuming, so could I send the two array to one only graph and create a kind of swithing to see one of the two plot on the same graph window? Thank you very much in advance for your help! G.
(3,892 Views)
Hi G.,
just open the context help for the graph. It explains how to wire more than one plot into a single graph...
(3,886 Views)
Thank you for your response, what help page are you referring? thank you, G.
(3,880 Views)
Hi Gould,
I was referring to the context help of a graph terminal:
(I'm using a German version...)
(3,875 Views)
Ah ok, that's right. But the multiplot shows both the graphs at the same time on the same window.
I would like to see only one of the plot, and switch to the second when I want.
Is possible? Thank you again. G.
(3,867 Views)
Hi Gould,
yes, that's possible.
- A graph shows just those data that you provide by wire. So when you want to display one plot or the other you should use a case structure or a select function to choose which plot to display.
- You may play with the visibility property of the plots...
(3,865 Views)
