graph two y axis hide one show another
I am using two y axis to show one is for voltage and other for current. I give a future to select voltage,currrent,or both. when user select voltage then second y axis should be disable. but for this one property node or terminal is needed there is no option of create when we click on y axis. please help how to do this?aaa.jpg
Message 1 of 8
(5,238 Views)
Hi kiwagh,
you can hide Y axis programmatically using a property of the axis…
Message 2 of 8
(5,227 Views)
hi GerdW,
Would you plz give the example of it.
Message 3 of 8
(5,221 Views)
Hi kiwagh,
create a property node for your graph, then select/use the properties ActiveYAxis and YAxis.Visible…
Message 4 of 8
(5,198 Views)
plz give the scrren short I am not able to find that property or is it same as Active Y Scale? if yes then I am passing 0 to it as its input datatype is numeric
Message 5 of 8
(5,155 Views)
Accepted by topic author kiwagh105@gmail.com
Hi kiwagh,
Yes, that's one of the mentioned properties.
When you wire a zero you ALWAYS select the first Y axis...
Message 6 of 8
(5,118 Views)
ok, but i want to hide it. please tell me how to hide it?
Message 7 of 8
(5,103 Views)
got the solution right click on graph->select create->property node->Active y scale->maker->visible
Message 8 of 8
(5,083 Views)
