graph window is constantly resizing when i use the 'hand' tool
I use to waveform graph which are synchronised concerning their scale range.  When I move one plot displayed on one of my waveform graphs, the other graph should display the same range of time. When I use the "hand" tool of the graph palette to move the plot of the first graph, the window of the graph is constantly resizing. How can i stop that?
In the enclosed programs, launch Offline.vi.
Thank you
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,678 Views)
Hello zyl7,
if you set the Properties of Y-scale to the values shown below, it doesn't flicker any more.
An you have to set "Autoscale Y" off. On load of the waveform you can use the property-node-property "Scale fit" with value 1. Then it's autoscaled once.
Greets, Dave
Message Edited by daveTW on 06-15-2006 12:52 PM
Greets, Dave
(2,675 Views)
Thank very much!!! It works perfectly!!
(2,666 Views)
