graph with fixed x scale beginning
Hi
I'm trying to display the online data in a graph with a fixed origin and a variable end.
The x scale shows time in seconds.
The fixed origin of the x scale is 0. Within the first 15 seconds the data fills out the graph. If the acquisition is longer than 15 seconds the end of the x scale is increased while the origin ins't changed.
I hope my description is good enough.
How can I do that?
Thanks for any help.
Yves
(2,899 Views)
A standard Waveform chart should do what you want.
ssk
(2,886 Views)
Hmmm, somehow I'm still stuck on this small problem.
When I'm running the attached main.vi the graph is initialized correctly but the x-scale doens't stay fixed on the defined range.
WHY?
Yves
The attached example is in LV 8.2.1
(2,849 Views)
