graph
Hi to all!
I'm trying to create a chart from an array (2D) of strings but I can not.
Someone would know help me please?
Message 1 of 14
(4,304 Views)
You can not plot 'strings' into Chart or Graph.
For that, convert strings in to numericals and then pass it to chart or graph.
Note:-
You can directly convert the number string into Integer/Double datatype by 'Decimal String to Number/Frac/Expr String to Number' function.
You can use 'Scan From String' function and 'Date/Time to Seconds' function to convert the time string into timestamp datatype and then double.
Yogesh Redemptor
Yogesh Redemptor
Message 2 of 14
(4,286 Views)
Thanks for the tip ... I attach the images of the front panel and block diagram of the specific case that I would like to solve.
Based on what you see, what do I do exactly?
I think the fundamental problem is related to the axis of the X (to make sure that the string "date - time" becomes in "date - time" format).
Thank you ...
Message 3 of 14
(4,282 Views)
To convert your string to a timestamp you need to use the "Scan from string" function; the correct format for your example is %<%d/%m%Y - %H:%M>T
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 4 of 14
(4,252 Views)
I used Scan from string function but an error appears... what kind of error is it?
Message 5 of 14
(4,248 Views)
Post the data..I means to say VI along with data
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 6 of 14
(4,244 Views)
You forgot a slash in the format string, so it doesn't match the input
Paolo
Message 7 of 14
(4,240 Views)
mmm... in wich position?
Message 8 of 14
(4,229 Views)
Ok, I forgot a slash typing the format. Now find the error.
(Hint: the format must preserve the input structure)
Paolo
Message 9 of 14
(4,223 Views)
Ok. Perfect.
It should work!
thank you very much
Message 10 of 14
(4,212 Views)
