graph
I want to plot two readings one is voltage and other is current but the ration of both are much more different means voltage range is in 1000 and current range is in 10, with reapect to time so I decided to make two Y axises one is for Voltage and other one is for Current. how can i do this by modifying existing one. please help.
(4,850 Views)
Accepted by topic author kiwagh105@gmail.com
Hi kiwagh,
Right click your graph Y axis and select "duplicate…" (or "copy…", I use a German LabVIEW version here)!
Then set the plot properties to have one plot for the 1st Y axis and the second plot with 2nd axis…
(4,804 Views)
There is no duplicate or copy option. y axis is not selectable
(4,785 Views)
try to hit one of the "numbers" with right mouse,
in all normal graphs/charts there is the option to "duplicate"
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(4,769 Views)
ok got it,thank you
(4,759 Views)
