graphic on cluster (4 élements)
i'm just a problem to make a graphic on a cluster with just 4 numeric element, i want to plot 3 curves on one graphic (X, Y1, Y2, Y3) but  it's impossible to make that. Somebody have the solution?
Thank you
labview 2013 full
(3,014 Views)
You have to build Cluster [(x1,y1)], Cluster [(x1,y2)], Cluster [(x1,y3)] and then build the array and connect to the graph.
(3,005 Views)
like that?it is very heavy and it does not work! I don't understand of what you wanted to say. there is no more simple?
(2,997 Views)
Accepted by topic author tisch
This is a way you can build your graph. Modify according to your requirement. The primitive I have used is "Replace array subset".
(2,982 Views)
ok!!!! thank you very much!
(2,977 Views)
