graphic-ring delete the frame
hello
i want to delete the frame which is around a graphic ring. There is a little white frame around my graphic-rings. how can i delete them? i want to have a grphic ring under another graphic ring, but there is allways this white frame.
(2,565 Views)
You should be able to paint the border transparent - select the brush tool and paint the foreground with the "T" colour
(2,565 Views)
