graphical circular fill
I've been looking for a gauge type numeric indicator that can show a type of circulr fill, as the needle on the gauge increase I would like it to fill the circle as it increase... almost like a type of dynamic pie chart, for example at 50% full I would like half the circle to be one color and the other half to be some other color... has anyone seen anything like this before?
much thanks!
(3,304 Views)
Use a picture indicator and draw a filled circle of desired size.
(3,292 Views)
well.... it would have to fill dynaically, like a numeric indicator, like a gauge, fill from 0 to 100% of the circle....
(3,283 Views)
An implementation of altenbach's suggestion (you'll need to replace the pict refnum and property node with an implicit property node due to the way snippets work):
(3,274 Views)
