graphics ring
Is it possible to import graphics into a graphics ring programmatically?
(LabVIEW 6.1)
(3,324 Views)
If there is one, I haven't found it. What you can do instead is have a 1D array of picture controls, and you can control which element of the array you're displaying.
___________________
Try to take over the world!
(3,310 Views)
This is kinda what tst suggested. It works for me and will programatically suck the JPG files from a specified path and allow you to ring through them. I use it so that I can add a new module to be tested without modifing anything in the code. Hopefully this will help solve your problem.
-Dave
(3,298 Views)
