graphing partial circles
I am creating a vi that graphs a circle from a certain interval, so like pi/3 to 2pi. I am using the sin and cos function. How can I graph these partial circles?
Chod
Message 1 of 11
(6,207 Views)
Can you attach your vi?
Message 2 of 11
(6,167 Views)
Hi Chod,
you can use an x-y-graph or you can draw the circle on a picture control.
Mike
Message 3 of 11
(6,158 Views)
hi chod,
  Have at this attachment..
Thanks and regards,
srikrishnaNF
Message Edited by srikrishnaNF on 04-30-2010 03:21 AM
Srikrishna
Message 4 of 11
(6,144 Views)
Hi Chod,
when using a picture indicator you can use the DrawArc function...
Message 5 of 11
(6,127 Views)
Here is kind of what I need, although I need to be able to have a control for when to start and end the angle. I want two controls on the front panel, so when I graph it I can display any segment of the unit circle.
Chod
Message 6 of 11
(6,093 Views)
Accepted by topic author Chod
Your For Loop just creates an array that has N of the same value.
Take a look at this.
Message Edited by Ravens Fan on 04-30-2010 11:08 PM
Message 7 of 11
(6,033 Views)
Awesome thank you! One more question about that. How do I start the circle at (1,0)?
Message 8 of 11
(6,027 Views)
and counter-clockwise
Message 9 of 11
(6,024 Views)
I just happened to go with the way you wired up the sin/cos function.  Looking at it more closely now, you had the output of sin going to X and cos to Y.  That's backwards from normal trigonometry.
Swapped the wires so that the Sine goes to the Y input and the Cosine goes to the X input, then you'll have it start at the right hand side (3 o'clock, (1,0) point) and it will go counter -clockwise.
Also, if you want to the center to be a different location, then you'll just have to add the new center point (currently 0,0) to the results of the sine and cosine function.
Message 10 of 11
(5,984 Views)
