graphobj.cpp error
I am trying to plot some data acquired from Tektronix LA. While generating Digital waveform,it gives error. (pic attached).
Any one has idea of how to solve this?
br,
vishal
(3,753 Views)
Hi Vishal,
Are you using any cursor property nodes in your VI?  If so, try deleting and re-implementing them.  The cursor property nodes have been tied to this specific internal error you are receiving.  Thanks!
(3,738 Views)
Hi Meghan,
I am not using any cursor property node in the code. Though I re-implemented remaining property node. but still error is there!
attaching the file.
br,
vishal
(3,730 Views)
I revisited the code.
I found one Cursor property node. I deleted that and replaced with new one. But still problem exists.
Any other comments?
br,
visha'
(3,721 Views)
Hi Vishal,
What version of LabVIEW are you using?  Also, could you please post the missing subVI, TLA721 Capture Waveforms to Image.vi?  Thanks!
(3,717 Views)
