graphs with report generator
hopefully this is one of my last questions about the report generator. This time the problem is how to get a graph in excel with the first column on the x-axis and the second column on the y-axis. What I get now is the first column as axis, and the other axis is something generated from excel, just as if I'm always using a bar plot, but then with dots. So the question is: how to say with column is x and with column is y with the report generator for LV6.i (as well for word as for excel)
Thanks.
(2,949 Views)
Found it myself:
my problem was solved using a constant is stead of a control to determine the type of graph.
(2,948 Views)
****THREAD HIJACK******
On the topic of Generating reports with graphs and such.... I was noticing when generating a standard report using the Report Generation VIs, when I append a graph using Append Control Image to Report.vi ... I lose sharpness of the image, and appears more pixelated then it does on the front panel.
Is there a way I can have that graph in my report without a loss of resolution?
It is most noteable in the numbers on the x-y scales, and the scale labels. Ive tried playing a little with the size of the graph when being appended using the property node, to no avail. Also tried saving as a png instead of jpg... which helped a little.
Any other options?
Thanks in advance.
Matt
EDIT: Posted this in the hardware threads also by accident... its better suited in the Labview threads though
EDIT2: Just noticed the loss in resolution is only in standard reports that generate PDFs... not in the HTML reports... losing the resolution in the conversion into the PDF.
Message Edited by MJBrehm on 07-06-2006 03:31 PM
(2,828 Views)
