greater than or equal to symbol on front panel
Is there a way to place the "greater than or equal to" symbol on the front panel as a font? I could do it as an image but I am not authorized a paint program.
(5,209 Views)
You just have to find a font that has the symbol you need.
Ben
(5,205 Views)
Use the number pad with the alt-key. Enter ALT - 0179.
If you see a superscript number three (³), use the select tool and select just the superscript three and then use text settings to change the font to Symbol.
(5,189 Views)
Another way is to use the Chart under START->PROGRAMS->ACCESSORIES->SYSTEM TOOLS->CHARMAP   (Think it's called Charmap in english, not sure though since I have Norwegian language).
Anyways. Here you can select "Symbol" as font, and you'll get a table with all the symbols. Copy the one you want and paste it in you FP in LV. Remember to select "symbol" as your font also.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(5,105 Views)
