>General question on VI modification
antonio ferrante wrote:
Yes, Ben.
Attached You can see a part of diagram I suppose to be responsible of change (it is marked by an arrow).
If i delete that while loop, Labview will not ask me to save  changed Vi.
Now I suppose there is no solution for this problem, anyway I learnd something more about Labview.
Antonio
That Q does not get asked for VI's opened and closed dynamically ( if I remeber correclty). So if you put that loop in a seperate VI and opened its FP OR you put the seperate VI in a sub-panel, lV MAY* not ask about changes.
Ben
*"MAY" = I'm not sure but I'd try the test if it was my challenge.
Message 11 of 12
(476 Views)
I have the same problem, but the message prompted to me is "Object resized on the front panel"
I try everything and dont work.
Bruno B. Costa
FAPESE - PETROBRAS/CENPES/NUEX
Message 12 of 12
(427 Views)
