guys look for this ERRORs
i m using LIFA(Labview Interface for Arduino) in LabVIEW virson 2010. I have installed it successfully but when i try to upload "LIFA_Base.ino" in my Arduino ,
i got these errors please have a look.
(2,546 Views)
I have the same problem.
(2,344 Views)
divy's last post was the post you replied to from February.  Nobody else replied.  You aren't going to get much benefit from bumping the thread versus creating your own thread.
Do you have the same version of LabVIEW?  What OS are you using?  Are you able to do anything else with LabVIEW or are you running into errors only when you use this functionility?
(2,332 Views)
Thanks, I'm new to this kind of thing. I actually was using LIFA but changed to Linx. Now thes sample program when I use the setup wizard works, but when I try running the sample RGB program nothing happens. I am using LabView 2013 student edition with an Arduino Uno.
(2,325 Views)
