hadware trigger to boolean
I have seen many examples for using a hardware trigger to start data acquisition, but I want to use a hardware trigger to start the recording of data to a file (acquisision has already started).  Essentially I want to take the trigger information and use it as a boolean to indicate whether I am taking data or not.  How would I impliment this?  Are there any helpful examples?
Thanks.
--Robert
(4,063 Views)
Are you refering to something like what is described in this link?
http://forums.ni.com/ni/board/message?board.id=170&message.id=190267
RayR
(4,061 Views)
Will the trigger outside the loop be able to trigger something inside the loop?  Lets say I have a Write to Measurement File Express VI and I want to use the trigger to create a true or false for the "enable" input to the VI.  So, if I put the hardware trigger to true, the VI will write to the file and if false, the VI will not write to a file.  I wasnt sure if a trigger outside of the loop could initiate things inside of the loop (using while loop, not for loop as in the linked example).
Sorry, but I am new to triggering.  And thanks for the quick reply.
--Robert
(4,058 Views)
Unfortunately I do not have LV installed on this PC, so I couldn't open the VI.
You should be able to place the trigger within the loop.  However, be careful not to activate the writing to the file unnecessarily at each iteration. 😉
A proper State Machine or Event Structure architecture would assure you to accomplish that.  Or at minimum, a Case Structure which selects (activates) the appropriate trigger to when writing to the file is appropriate.
Short answer:  yes, you should be able to trigger within the loop.
RayR
(4,053 Views)
I will work on that then.  Thanks for your help.
--Robert
(4,047 Views)
Let me know how it goes.
RayR
(4,029 Views)
