handle array in multiple for loops
Why do you have the inner while loop?
Why you initializing that inner while loop with an empty 3D array?  As a result of that, your outer For Loop will run exactly 0 times, and you'll get nothing in the end.
Please attach an actual VI and not a jpeg that contains some real code with real data.   Otherwise I'm not going to be able to help anymore.  I'm afraid that your convoluted attempts so far mean you really don't understand arrays and the different array functions in LabVIEW.  I would recommend looking at the online LabVIEW tutorials:
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 11 of 15
(1,249 Views)
In addition to what RavensFan requested, please provide an example spreadsheet file (.csv, .xls, etc.) of what you want the data to look like.
Message 12 of 15
(1,245 Views)
Thanks for the assistance all... please see the attached stripped program and output file i am expecting that the data file would be what i could pass out to create a measurement report based. I do apologize if my phrasing is convoluted. This issue is rendering a significant time suck for me.
Message 13 of 15
(1,222 Views)
This VI will show you how to arrange the data in the way you want on your spreadsheet. The "Initialize Array" function just makes the 4 datapoints that it looks like you are collecting, so that's where your actual data would go.
One suggestion, instead of making a separate shift register for each data type, you might consider having fewer, or even a single shift register which holds a cluster of all that information.
Message 14 of 15
(1,211 Views)
Thanks for the help
Message 15 of 15
(1,204 Views)
