hard drive temp monitor
Is there a way to monitor the hard drive temperature using Labview?
(2,544 Views)
Hi WayneR!,
There is no native way to access hard drive temp through LabVIEW so you would need to take advantage of some other software tool. Below is a link to Microsoft's Sensor API. You may be able to find a dll that works here.
http://msdn.microsoft.com/en-gb/library/windows/desktop/dd318953(v=vs.85).aspx
Best Regards,
Chris
National Instruments - Tech Support
(2,473 Views)
