hardware timeout error
I was just wondering if anyone knew how or if it is possible to adjust when timeout errors are passed in labview. I occasionally get a hardware timeout error passed in when my code is running. I think the error code is 10001. I would like to adjust the settings, specifically how long LabVIEW waits before passing the error. Is this something that can be done?
Thanks!
(3,520 Views)
I think that error code 10001 actually wrong, my apologies
(3,518 Views)
Could you be more specific on what your code is doing? If you're reading data with DAQmx, there should be a timeout terminal on the read function: https://www.ni.com/docs/en-US/bundle/ni-daqmx-labview-api-ref/page/vi-lib/daqmx/read-llb/daqmx-read-...
Also, if you could respond with the actual error that may be helpful as well.
(3,453 Views)
