hasp .net constuctor
Hello all,
i'm trying to protect my software a little bit and for that, I'm starting to use USB hardware key. The manufacturer it's the "Alladin". This supply the .net constructer that I can use in Labview. I'de tried on VB.net and the software work well. But the ideal would be to call the methods on labview. But calling the same methods on Labview return in error.
Only with this Info someone can give me a hand?
Software developer
www.mcm-electronics.com
PORTUGAL
(3,122 Views)
What kind of error do you get? Does it occur with the constructor, when you call a method, or a property?
(3,109 Views)
Hello and thanks for your help.
I'm not getting the Labview error (labview error cluster returns OK), but the method returns a status saying "invalidobject".
I've attached the small test that i've made.
Software developer
PORTUGAL
(3,105 Views)
Sorry, I don't have LabVIEW 8.5. Perhaps someone with 8.5 will be able to take a look at the VI. I suspect, though, they may need to have the .NET library in order to try it.
(3,103 Views)
