have 4 wave forms in a graph need to split into 4 indicators
 I have 4 readings coming out from my DAQ. Which is seen in a single graph. When the output is connected to an indicator it is showing the output for only my first channel. i want to see the result for all the four readings in separate indicator. Please help!!!!
(2,750 Views)
Can you show the code you are using, and say a bit more about what you want to do? The graph where you are seeing all of the channels is an indicator. What other sort of indicator do you want to use?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,741 Views)
