I have an excel file that has 2 columns. i want to search the first one with a constant, then return the corresponding data in the second one to labview, preferably in some kind of string variable. is this possible and how? Thanks in advance
Yes, you can use ActiveX to read a table of an Excel spreadsheet. Search the examples that ship with LabVIEW, for ways to get started with this. "LabVIEW\examples\comm\ExcelExamples.llb"
Once you have your two columns, use a Search 1D array on the first column and then index out the value in the second column with the index of the found element.
